Anyone know why rad can't touch metal?????
Old Nov 2, 2002 | 02:15 PM
automorph's Avatar
Car: 89 Trans Am
Engine: 3.1 V6
I read somewhere that rad should not touch metal? I want to make a bracket to hold my rad, what material should I use?
Old Nov 2, 2002 | 05:31 PM
Andy Bush's Avatar
Copper or aluminum should not contact steel or other diffrent metals, because a galvanic cell is set up and you get rapid corrosion. You can insulate the bracket from the radiator using plastic grommets or anything that stops an electrical circuit forming, but can withstand the temperatures.
Old Nov 3, 2002 | 02:48 PM
MdFormula350's Avatar
so basically make the bracket out of the same material as the rad or just insulate it..
Old Nov 3, 2002 | 05:22 PM
82camaro's Avatar
Car: 82 camaro SC
If it touches metal, it can also wear a hole it it from the vibration of the car. If you have metal to metal, make sure it's really tight and can't move at all. Or just insulate it.
Old Nov 4, 2002 | 02:17 AM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
I have heard it called metal biasing. If you look at a aluminin sun roof it will not rust it will just oxidize and flake apart. That is why we have so much trouble with our batterie cable connection. Rubber shoudl work fine as a cushion.
MrPackstin
Oct 25, 2017 08:09 PM
Night rider327
Feb 25, 2016 09:50 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
