JEt Products fan switch
Old Nov 6, 2002 | 12:53 PM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
purchased a jet fan switch 180 stat and stage 2 chip for my 89 firebird formula Lo3 (305 tbi) in traffic and idle temp seems to creep up to 220 is this normal shouldnt the fan be comming on and cooling it. anythign to check for
Old Nov 7, 2002 | 12:20 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Don't take offense to this question, but did you mount it in the right spot between #6 and #8?
I have the Hypertech equivilent 180* and it's been a long time since it's crept up that high.
AJ
Old Nov 7, 2002 | 06:57 PM
MdFormula350's Avatar
well what thermostat do you have??
the fan should come on at 180, does it???
220 is warm, it should be like lower than that even with a 195 in it and the fan running turning on at 180!!
need more info....
Old Nov 8, 2002 | 02:28 AM
AJ_92RS's Avatar
The Jet and Hypertech 180* fan switches come on at 200* and off at 185*.
And he states that he has a 180* t-stat. Or do you mean what brand?
AJ
Old Nov 8, 2002 | 11:15 AM
hypertech makes two different fan switches
02-4026 Hypertech Cool Fan Switch [cuts on at 176, off at 166 degrees F]
02-4028 Hypertech Cool Fan Switch [cuts on at 200, off at 185 degrees F]
i must of read the post to quick, i see that now he has a 180 thermostat..
then something is wrong still, should be at least under 200! even in traffic..
Old Nov 8, 2002 | 08:26 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Originally posted by MdFormula350
.....then something is wrong still, should be at least under 200! even in traffic..
Not if you're making real hp.
:lala:
64goatman
Sep 9, 2015 01:09 PM
luvofjah
Sep 3, 2015 07:08 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
