is my car running hot or too cold?
Old Nov 10, 2002 | 02:41 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I have a 383 with AFR heads on there. I have the 1-1/4" griffin radiator. I have a 160 degree thermostat with two 1/8" holes drill in it. I also have a edelbrock water pump. My autometer gauge on the car reads 200 degrees at the head when i'm sitting at a light, it reads 180ish on the highway. My instrument cluster gauge reads close to the 160 mark in town. It reads in between the 100 and middle mark on the highway. My car ran around the 200 mark on the instrument gauge in my car with all old radiator. I just wanna know if my car is running way too cold or hot for this setup.
Old Nov 10, 2002 | 03:23 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
If your air dam is in place , it seems that your temps are fine (p.s. , the factory gauges are rarely accurate, go by the autometer gauge), does the car have an electric fan(s)?, if so, you may benefit having them turn on at a lower temp(170-175?)
Old Nov 10, 2002 | 03:37 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I do have electric fans i might change that temp. setting in the PROM when i get into prom burning.
Old Nov 10, 2002 | 10:12 PM
MdFormula350's Avatar
i would trust the 200 / 180 temp from the autometer gauge...
if thats good enough for you then leave it!!
theshackle
Mar 5, 2017 06:37 PM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
86Base
Aug 8, 2015 01:34 PM
