High Flow Thermostats
Old Nov 15, 2002 | 05:02 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Do they really flow more then the crappy two dollar ones. I think their official name is a MacPherson or somethign. Stewart recommends you get one with their water pumps. I have a Stewart stage one pump and a crappy two dollar stat. Do the other ones really flow more?
Old Nov 16, 2002 | 11:48 AM
breathment's Avatar
i don't see how it can hurt anything. its good insurance..
Old Nov 18, 2002 | 02:39 PM
ttt
Old Nov 18, 2002 | 03:43 PM
82camaro's Avatar
Car: 82 camaro SC
Some of the 'better' thermostats open smoother(instead of just open or shut) and help keep the engine temp more constant--which is good.
Old Nov 19, 2002 | 07:01 PM
MdFormula350's Avatar
i would follow what they say and get a high flow one..
Old Nov 19, 2002 | 10:28 PM
yeah i probably should right
Old Nov 20, 2002 | 02:19 AM
SpeedCat86's Avatar
Car: '86 TransAm WS6
Transmission: Custom TH700R4
The thermostats that Stewart reccomends are the RobertShaw thermostats. They use a different mechanism than your traditional spring-style 'stats that is generally accepted as more accurate, in addition to having higher flow characteristics due to a straigher flow path.
I've seen them at one of the auto parts places around here for about $8-10.
The ones that Stewart sells for their Stage II and III pumps comes with a couple of bypass holes drilled in it, as shown below. I run a 195* on my car, with a Stage II, and it runs at a rock-steady 200* all the time, no matter what weather conditions, slightly cooler on the highway, and still less than 220* on the race track
Old Nov 20, 2002 | 08:06 AM
thats. the local autozone has them for <$10. i might drill a couple 1/8" holes in it. thanks
brady
Old Dec 18, 2002 | 01:24 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
dont buy one theyre a joke and awaste of your time and money i got three in a row and none of them worked not one and theyre suppoed to be the"failsafe" design the only gets stuck open right .............well,. all of mine got stuck closed..........biggest pos,s ive ever seen
Old Dec 18, 2002 | 07:24 AM
i just bought two this weekend. they both would not open. biggest PITA and POSs. i wont buy one again...
Old Dec 19, 2002 | 03:15 AM
Just buy a regular cheapy Stant thermostat and drill a couple off small holes in it. That's what my friend did with his car and it helped out alot. Mine's getting that done as soon as the weather starts to get hot again.
Old Dec 19, 2002 | 07:04 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Stant is not a cheapie as you call it. They are the OE supplier to GM and a whole host of other manufacturers. The stock GM or a Stant replacement will work fine for any application. Considering the amount of Stant stats out there I would say they are pretty darn reliable. For TG's they have 160, 180 and 195 units in stock at most retail outlets.
Old Jan 1, 2003 | 10:48 PM
1985Camaro's Avatar
robertshaw thermostat
I just bought a robertshaw thermostat, it was $6 but it doesn't look like the one in the picture it looks like the normal ones. It is called like generation II or something. I'm putting it in tomorrow, I went with that one cause it was the only thermostat they had in stock to fit... but I will be drilling acouple 1/8 holes in it tomorrow before it goes in.
Old Jan 1, 2003 | 10:51 PM
1985Camaro's Avatar
Oh yeah and I went with a 195 degree stat
Old Jan 1, 2003 | 11:03 PM
thats the one i got
i got two of em neither opened
keep an eye on your temp and dont drill holes you might need to return it
Old Jan 2, 2003 | 12:39 PM
1985Camaro's Avatar
Is there a way to test it before going through the hassle of putting it in??
Old Jan 2, 2003 | 01:58 PM
1985Camaro's Avatar
I just put it in some boiling water and used a thermometer, did it a few times just to make sure. That should be enough right?
Old Jan 2, 2003 | 09:28 PM
up to you man, i put mine in water and i didnt see it open, then i took a 'stat that i knew worked right and put it in boiling water and it looked like it didnt open either (but i am 100% sure it works correctly)
Old Jan 2, 2003 | 09:48 PM
1985Camaro's Avatar
we'll see how it goes, I have to wait till tomorrow to get some gasket remover. It was funny I got the thermostat housing opened and to my surprise there was thermostat in my car! Oh well I guess thats why it never heated up.
Old Jan 6, 2003 | 09:09 AM
Elric's86-Z's Avatar
I installed one of those high dollar thermostats in my camaro an firebird as well as everything else an never had a problem outa anyone of them.
One question, why go w/ the 195deg????? way to hot.
the whole point is to reduce eng temp an increase power.
I went w/ the 180 w/o affecting my computer,the car runs great.
Old Jan 6, 2003 | 12:40 PM
1985Camaro's Avatar
I got a 195 to be safe...there has been way too many posts arguing what is better and there doesn't seem like there is a definate answer. I don't have a chip and don't plan on getting one anytime soon so I didn't think that going with a lower thermostat would help me out, thats all. There are tons of posts about what should be the temp. And I have no performance mods so I really didn't care, I'm just getting frustrated with my car and want to get everything fixed before i think about anythign else.
Old Jan 11, 2003 | 08:19 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
well i can add to the negative response of "high-flow" stats... had one in my '91 TPI, stuck the whole time, after i replaced the previous brand new one for doing the same thing. put a stock gm 195* and all is well. running a stewart hi-flow pump, too. temp stays around 170, according to the dash gage, but i have a 200 on/185 off switch installed as well...
KAM
Bubbajones_ya
Jul 6, 2024 08:32 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Stryker412
Sep 20, 2015 06:59 PM
corey8084
Sep 17, 2015 02:56 PM
89fast5oh
Sep 8, 2015 09:55 AM
