Heater Valve diverter....
Old Nov 17, 2002 | 11:56 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
mine blew up.... i bought a new one....
heres wher emy question arises..before i bought it my car did this really retarded rpm spazz, where at an idle the rpms would fluxuate. now first thing that comes to mind is a MAF. so i decided to start saving for one (performance of course). anyway the maf started pulling codes, so i ran a diagnostic and sure enough it was a the MAF. so im still savign and this stupid little heater valve thing expodes(horrible mes sinside the hood ) anyway, i replace the heater valve diverter, and my car doesnt do the RPM increase. is this normal? does the vaccuum line that does from it to the ac dash at all interfere with the vaccum system in the car? more importantly is this what fixed it? if so i have a friend with an 86 firebird that has the same problem with the rpm fluxuations, but has yet to buy a MAF and his isnt pulling codes. anyway i have checked teh searches and nothing of this sort has come about. any explanations?
Old Nov 18, 2002 | 12:49 PM
Andy Bush's Avatar
What fault codes were you getting, and did you clear the codes. If you have a vacuum leak, misfire, or other vague faults, they can give a vacuum fault. Also vacuum leaks could affect the tick over.
Old Nov 18, 2002 | 06:11 PM
HamSpiced's Avatar
no vaccuum leaks or anything, the code tha twas pulled i believe was 32. it was whatever one was related to the MAF.does it at all matter that as the rpms peaked teh voltmeter would kinda go up and down??
Bubbajones_ya
Jul 6, 2024 08:32 PM
drptop70ss
Oct 4, 2015 09:44 PM
Formula8r89
Sep 22, 2015 04:24 PM
355tpipickup
Sep 13, 2015 11:35 PM
sandman92084
Sep 12, 2015 10:27 PM
