duel fans
Old Nov 18, 2002 | 10:31 PM
paul russell's Avatar
Car: 86 trans am
Engine: 5.0 tpi gtauto ramair and notch
Transmission: 700 r4
duel fans
will duel fans realy make a cooling diff. i have heard mixed feedback from some shops in the area..wanted to get some feedback from anyone who did the mod and was satisfied with the results...thanks
Old Nov 19, 2002 | 07:10 PM
MdFormula350's Avatar
are you having overheating problems?
dual electric fans were used on the 350 tpi cars.. but really the passengers side fan is only a back up, turn off at like 238... or when using a/c...
however i hardly even use the drivers side fan because i do mostly highway miles to work and since its winter i dont get high enough to turn on the drivers fan...
so they are good to have if you want someback up just incase..
Old Nov 19, 2002 | 09:35 PM
camaro6spd's Avatar
dual elec fans came on all TPI cars, and mine just fried out and i thought the passenger side(secondary) turned ON at 233.....and the driverside(primary) turned on slightly before or after.
Old Nov 19, 2002 | 10:19 PM
Car: 86 trans am
thanks my car was not overheating but was running realy close to it though. i was going to run both fans at the same time for extra cooling but wasnt sure if it was a wast of time.or putting the second fan on a togle and using it when needed..
Old Nov 20, 2002 | 08:23 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
i have a full stock 305 and i have dual fans...however the pass side relay went out and im too broke to fix...
Old Nov 20, 2002 | 11:13 AM
yeah i only spoke from my experience that i have. and that has been with 350 tpi thirdgens!
Old Nov 21, 2002 | 04:52 PM
Desert86Roc's Avatar
Sorry, dual fans did not come on all tpi cars...only 350s. Anyway, YES dual fans make a difference.
Go here http://www.metzlerracing.com/dualfans.htm for details on doing a conversion.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
