overheating
Old Jan 11, 2003 | 05:03 PM
VashtheStampede's Avatar
Car: '84 Z28 Camaro
Engine: 305 V8 5.0L H.O.
Transmission: T5 manual 5-speed
overheating
I have an 84 Z28 Camaro, with a 5.0L 305 V8 H.O. engine, I've been driving for a while, but just recently its been overheating or acting like it was. I've read many forums ,but I'm having a difficult time determining my problem. I already replaced the thermostat and the radiator cap. The symptoms I experience are: temp. gage shows that the engine is overheating and the coolant boiols and sprays out of the cap on the coolant tank, but when i replaced my radiator cap it stopped boiling over, but it was still overheating. I've been told that it could have to with any of these components: thermostat, radiator cap, clog in cooling system, air dam, fan/fan switch, air leak; but I need help determining which one(s) it is. Any thoughts?
Old Jan 11, 2003 | 07:16 PM
1986redbird's Avatar
I'd start with the easiest thing to check first,
when the engine is warm/overheating check and see it the fan is comming on.
if it only overheats on the highway then look under the car and make sure the air dam is there.
with engine cold take radiator cap off, start car, let warm up, look and see if the coolant is circulating.
Old Jan 11, 2003 | 09:42 PM
86FirebirdV8350's Avatar
Car: 91' Firebird
Engine: 3.1L V6
Transmission: WC T5
ok..this just happened to my car...I replaced the thermostat, got new gaskets and a whole new coolant temp sensor. when it overheats no heat comes from the vents right? thats what happened to me...start with the thermostat first though
Old Jan 12, 2003 | 01:20 PM
MdFormula350's Avatar
also what kind of coolant mixture are you running..
Old Jan 12, 2003 | 02:14 PM
89rsIMPRTETR's Avatar
it could be that your gauge is just not reading correctly, i know alot of people have said that there factory temp gauges sucked, i know for a fact on mine it was reading 20 degrees hotter than it actually was, just take your car to a shop, have them check the temp with some laser thing they use, and see if your gauge is off cuz it very well could be
Old Jan 12, 2003 | 11:47 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Waterpump?? Got to check everything ya know. My friend had a 91 Bird and his coolent was boiling out of the overflow valve and thats what was wrong with his who knows check and see.
Old Jan 12, 2003 | 11:58 PM
RallyeNate's Avatar
Car: 85 IROCZ
Engine: 305ci
have you pressure tested your coolent system, if your leeking pressure your car will overheat
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
