In the shop for new Intake Man. Gasket...
Old Jan 19, 2003 | 06:23 PM
YellowIROC305's Avatar
Car: '86 Camaro IROC-Z28
Engine: 305 V8 (LB9)
Transmission: 700-R4
My IROC's been leaking a little coolant off and on for months now, but just two days ago it turned into a waterfall, so I took it into a shop here. They said it is a bad intake manifold gasket which I heard is a common place for coolant to leak. Anyways, they are charging me $415 for parts and labor. Does this sound reasonable? I know it is possible to do it yourself, despite a lot of monkey-work taking the intake off, but I don't have the time to do it.
Old Jan 19, 2003 | 09:31 PM
MdFormula350's Avatar
for that money i would definitely try it myself first!!!
should take no more than a day, with hand tools..
i never had to change one yet..
Old Jan 19, 2003 | 10:57 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
for that money buy a new intake and put it on yourself and save 200+ dollars
Old Jan 19, 2003 | 11:00 PM
mrbboy's Avatar
I agree. For that much money, you are better off doing the work yourself. When I did mine for the first time, I think I only spent about $50 for the gasket set and some rtv. It also took me 2 days to do it because it was my first time doing that repair and I didn't want to screw anything up. It's pretty straight forward but I do recommend you get a timing light. It makes checking and adjusting the timing much easier after you reinstall the distributor. You might as well replace the distributor gasket as well. So, save your money and do the work yourself and you'll have a better appreciation for the inner workings of your car. Good luck and if you have any problems, just post them here and I'm sure people here would be more than happy to guide you.
Rene
91 RS 305
Old Jan 19, 2003 | 11:04 PM
llvll4l2c91350's Avatar
The FelPro gasket kit for TPI engines is only like 20 bucks and it comes with all the gaskets you will need. Even the distributor gasket. And yeah do get a timing light so you can adjust the timing. I've done this twice on two different cars already and it's no biggie. Make some time and try it out yourself first!
Old Jan 20, 2003 | 06:04 PM
Thanx guys.
If all else fails, i got a 10% off coupon they sent me in the mail.
IROCZ1989
Jan 24, 2016 03:55 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
DJanes97
Sep 1, 2015 02:55 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mustangman65_79
Aug 8, 2015 12:07 PM
