Search is down...got a question for a friend....Help!
Old Feb 7, 2003 | 01:42 PM
billsfirebird's Avatar
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
A co-workers son just got an 89 Camaro RS with the 305 motor. I haven't seen his car yet so I don't know all the details on it.
Okay so my co-worker asked me what could cause a car to run hot. I told her that the thermostat could be bad, or the radiator may not be good anymore.
She said her husband has replaced the thermostat and flushed the cooling system. He read in the manual there are four sensors that could be the culprit but only could find 3 of them and replaced them.
The motor is still running hot.
I told her to take out the radiator and wash it real good. I also said for them to check the fan. I don't know if it is electric or engine driven. If it was electric I told her to check the relays to the fan or if it was engine driven to check that the fan blades are not bent up wrong.
I don't know what else to say....what do you all think? Is there something here that has reminded you of a similar problem? Can you guys help?
Thanks again.
bill
Old Feb 7, 2003 | 01:52 PM
1986redbird's Avatar
I don't know when it's overheating but, first of all its probably an electric fan setup. second if it overheats when moving slowly then its probably the fan(s) not coming on, if it overheats when going over 35 or 40 mph then it may be missing the air dam under the nose. our cars are notorious for loosing the air dams and will definatly run hot without it.
Old Feb 7, 2003 | 05:20 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: Search is down...got a question for a friend....Help!
Thanks again.
bill
Give us more info, then we can ALL help you. Most of the problems with TG's despite what you read are easily solved. There is no magic answer but the more basic diagnosis we can get the better we will be to help. Dan
Old Feb 8, 2003 | 12:58 PM
MdFormula350's Avatar
if its overheating in traffic, my guess would also be the fan is not working right, and on the highway it could be the airdam..
MustangBeater20
Oct 29, 2022 09:20 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
