What will happen if radiator touches metal on the car?
Old Mar 8, 2003 | 12:50 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
I am installing my universal griffin radiator, and I was reading that article that Jim wrote. He mentions that no part of the radiator should touch any metal parts on the car. Why is this? I think I have it in there pretty good but he has me worried that maybe a small part may be touching and I don't want to screw anything up.
Old Mar 8, 2003 | 06:18 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
You don't want the radiator rubbing on metal because it may damage it. The steel frame work could cut through an aluminum tank. On a side note, I installed a Griffin rad. with Spal dual fans and that team can cool. I run a 160* stat and cruising down the streets with the air on full, I run steady 160-170*. On the highway, I stay just above 160*.
1992 Trans Am
May 10, 2023 07:19 PM
jhawkeye
May 25, 2022 06:33 PM
mustangman65_79
Sep 1, 2015 03:51 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
