heater control valve/diverter & HSR
Old Mar 19, 2003 | 02:39 PM
dantheihatemustangsguy79's Avatar
i have a quick question. my hsr intake only has two holes into the front water passage. one i stuck the temp switch in and the other i plugged.i was gonnga plug the hole from the heater control valve/diverter then i noticed in antoher pic on this site, that the guys HSR intake has 4 holes for access to the front water passage. one for the switch, one for the heater control valve/diverter, and the other two plugged.
so the question is do i have to run a line to the heater control valve/diverter from the intake or can it be plugged?
Old Mar 19, 2003 | 03:10 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
A picture is worth a thousand words. Delete the ugly diverter valve and plug the vaccum line. Run one hose from the heater core to the radiator. Run the other hose from the heater core to the fitting specified in the picture.
Attached Thumbnails heater control valve/diverter & HSR-engine_0037.jpg
Old Mar 19, 2003 | 03:57 PM
JMatlock88's Avatar
Car: 1991 Formula
I am oil cooler delete because of the long tubes. If you have the oil cooler,you will need to modify the hose from the heater core to the radiator. Do this by routing this hose to go from the heater core to one of the oil cooler pipes. The other oil cooler pipe then connects to the radiator. This simply includes the oil cooler in the coolant loop.
Old Mar 19, 2003 | 04:54 PM
I think i'm just gonna hook up the bypass valve to the intake for now. mabyee i'll do the setup your talking about later. thanks for the advice
Bubbajones_ya
Jul 6, 2024 08:32 PM
Formula8r89
Sep 22, 2015 04:24 PM
Doobie52
Sep 11, 2015 06:19 PM
dbrochard
Sep 7, 2015 09:41 AM
Jlanz55
Sep 6, 2015 02:35 PM
