engine overheats occasionally
Old Apr 2, 2003 | 12:35 PM
mdr211's Avatar
Car: 86 camaro Z28
Engine: 305 carb
I have an 86 z28 with a rebuilt 305 w/ carb...it sat through the winter, i just put a new battery in it and ive been starting it every few days to air it out...today i started it and i let it run till it was hot and when i shut the engine off all the coolant started to bubble out into the overflow reservoir and there was steam everywhere...now ive always had problems with overheating, mainly on very hot days.. is there anything i might try to help my car run cooler? usually its at its worst when im idling at a stop light or something like that on a very hot day, then i just turn on the vents full blast and sweat my ***** off while i watch the temp gauge go down! it sucks but it works...this spring i want to fix this overheating problem once and for all so any suggestions will be great...i would like to switch the radiator cap and get a new thermostat, i dont know what thermostat to get though?? also i was wondering if flushing the radiator would possibly help...maybe a larger water pump?? what do you guys think?
Old Apr 2, 2003 | 12:50 PM
84 Z28 5.0 HO's Avatar
Car: 84 Camaro Z28
Engine: 305 L69
if I were you i would check to see if you radiator fan is operating correctly
Old Apr 2, 2003 | 03:15 PM
mdr211's Avatar
Car: 86 camaro Z28
Engine: 305 carb
yea im hoping thats the problem...ive done a lot of reading through past posts and it seems thats a pretty common thing with these cars...we'll see...i just pulled my car into the garage for the first time this spring and i cant wait to get started...ill be a regular here before you know it...
eightsixseven
Dec 16, 2024 01:50 PM
bryan623
Mar 22, 2021 06:43 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Irocohio
Aug 12, 2015 08:03 AM
