Is leaking radiator tanks common?
Old Apr 20, 2003 | 10:39 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I just replaced my radiator because of a leaking tank. I was wondering if this was a common problem with our cars because this is not the first time I had to do it. The radiator shop told me it was because I had exhaust gas leaking into the system. Is this true and if so how do I fix it? Or is it B.S.?
Old Apr 20, 2003 | 11:52 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
It may be, as I've sort of gotten used to it over the years.
At first, several years back, I tried taking it out & letting a shop fix it. But after doing that a couple of times & ended up both times pulling it out again 2-3 times after they claimed it was "fixed", I decided that it was cheaper in the long run to just replace the radiator.
Did it in my daughters car a couple of years ago, & am doing it in mine this week!
Old Apr 21, 2003 | 05:25 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It is fairly common and it has nothing to do with anything other than the tank fatigues from all the heat/cool cycles. Generally they develop a crack a few inches down from the rad cap. AC-Delco sells the tanks separately for about $30 or so. They average around 10 yrs so you will be OK for a while.
Old Apr 22, 2003 | 04:16 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I've replaced the radiator in all four of my past 3rdgens because the plastic tanks always leak eventually. Back when I was single and could afford such things, I replaced the radiator in my '83 Z with an all aluminum one and never had another problem with it.
Old Apr 22, 2003 | 05:00 PM
RAD5's Avatar
Car: 89 Formula 350
Engine: 5.7 TPI
I just wanted to make sure there was not anything else wrong to cause this. I replaced the whole radiator with one that has a lifetime warranty just in case it happens again.
Old Apr 22, 2003 | 05:59 PM
Car: 1987 Z28
Engine: LG-4 305
That is what I am doing with the Oreillys radiator I just got. I also checked my maint record & the old one had been in for about 9 years.
Old Apr 22, 2003 | 08:38 PM
RSFreak's Avatar
...one that has a lifetime warranty...
Smart move!
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
Strick1
Sep 6, 2015 10:38 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
