Fan kicks in really late.
Old May 10, 2003 | 02:18 AM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I got a 91 RS V6 camaro and I just replaced the fan motor and fan relay and it kicks in about 3/4 of tempeture gauge. I dont think its normal and always thought its supposed to kick in at about 260 (or halfway if your temp gauge is different). It was doing this on the old fan motor as well. It kicks in right away when I turn on the AC like it should. How do I set it to kick in quicker? Thanks for the help.
Old May 10, 2003 | 07:59 PM
pasky's Avatar
No one?
Old May 10, 2003 | 08:46 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Change the fan switch. I'm not sure whre it is on a V6 but, on a 305 it's on the passenger side head between the #6 and #8 spark plugs.
Old May 10, 2003 | 09:50 PM
pasky's Avatar
Thanks.
Old May 10, 2003 | 09:53 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
on a v6, I think it is t the rear of the pass head, above the exhaust manifold
Old May 11, 2003 | 04:15 PM
zer0321's Avatar
my 92 3.1 camaro has the same "problem"....from what I hear these engines were meant to run hot, and the fan kicks on at about 240* stock...to change this you either gotta get a new thermistor (to trick the ECM) or a new chip for the ECM, because there isnt a fan switch on the 3.1 v6's
also if you have A/C (unlike me) you can just turn that on, which will should turn the fan on automatically and cool it down...
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
tattmann
Sep 27, 2015 05:20 PM
