Lighted Manual Fan Switch
Old May 15, 2003 | 12:45 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
I'm working on putting in a manual fan switch. The switch I have has three terminals: supply volts, on acc., and earth ground. I know the ground is connected to ground, but where should I connect the other two? If at all possible, I would like to also like the switch to be in parallel to the current curcuit. Any help would be appreciated.
(sorry for the double post, but wasn't sure where to put it.)
Old May 16, 2003 | 01:45 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
My advice would be to wire the fan in with a relay... Positive from the switch to the ign switched fusebox terminal.. Negative to ground... Accessory to the positive terminal for the relay power...
Relay ground to ground, then one wire from the battery, then to the fan.... There's tech articles for it that go into more detail... Definately don't want the power for the fan going through the switch...
eightsixseven
Dec 16, 2024 01:50 PM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
stalkier
Aug 21, 2015 01:54 AM
TA8487
Aug 16, 2015 12:21 PM
Omega
Aug 10, 2015 12:46 PM
