Coolant Leak?
Old Jun 3, 2003 | 11:14 AM
frbrd87's Avatar
Coolant Leak?
I have an 87 Formula and I have been having to add coolant to it. Replaced the hoses, they were not the source of the leak. No fluid under the car either. Any thoughts on what might be going on here?
Old Jun 3, 2003 | 07:33 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
well have you noticed any smoke during start up? Whats your oil look like? what do your plugs look like? since you cant seem to find any on the ground the leak may be an internal problem but you may also want to look around the heater core and follow all your hoses in the engine bay and look for signs of leaks.
Old Jun 4, 2003 | 12:24 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Do you hear any gurgling sounds coming from the firewall area? Losing coolant without any leaks usually means the head gasket has a tear in it allowing coolant to seap into the combustion chamber and being burnt with the air fuel mixture.
Old Jun 4, 2003 | 06:27 AM
frbrd87's Avatar
Thanks for the replies. There is no smoke at all, and the oil looks clean. I will follow all of the hoses and check again.
Old Jun 4, 2003 | 06:37 PM
mechanicalmehem's Avatar
get a mirror and look at the bottom of your water pump, it could be seeping causing a small leak.(but evaporating before it hits the ground.
Old Jun 5, 2003 | 12:11 PM
Morley's Avatar
Check the area of the block around the starter right after shutting off the engine. Intakes like to leak at the water passage at the back corner by #8 cylinder.
Old Jun 5, 2003 | 12:57 PM
91Z28-350's Avatar
get a uv light and dye kit. The dye will show even if the coolant dries up. Put in the dye, drive around for a few days, then check with the light and glasses. The leaking areas will jump out at you.
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
