Fans not working
Old Jul 10, 2003 | 05:13 PM
Beast_Vert350's Avatar
Fans not working
I am trying to figure out why my fans on my 88 305tpi IROC arent working. At first I thought it was the switch in the block, because the connector for it broke off and the wire wasnt able to plug in. So I replaced the switch and added the connector. But still I get no fans. I am thinking the relay(s). I want to get this fixed so I can drive the car and not worry about getting stuck in traffic and having to pull over cuz the car overheats. I am just asking if it would be the relays or something else.
Old Jul 10, 2003 | 07:14 PM
Well I just went out and looked around to see if I can see if anything around the fans, the wiringm or anything else was out of the ordinary, and all I can say is HOLY HELL!!!!! I am surprised the car even runs because those wires are a freaking mess!!!!!
My next question.. does GM sell the wiring from the dual electronic fans to the relay? If not is there a aftermarket/performance upgrade out there that replaces the wiring (ie new fan setups). It is such a mess I dont even think going thru and taking the month its going to take to rewire everything is even going to work.
Old Jul 13, 2003 | 12:00 PM
HanSoloWS6's Avatar
Car: '05 Pontiac G6
Engine: 3.5
Axle/Gears: Slow lol.
How hard was it for you to change the switch and connector? I have the same problem with the connector being broken. And how much did the switch and wire run you?
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
TA8487
Aug 16, 2015 12:21 PM
Leggman1
Aug 6, 2015 04:15 AM
