Cooling Problem !!
Old Jul 15, 2003 | 01:12 AM
IroczCamar0's Avatar
Car: 1989 Pontiac Trans AM GTA
Cooling Problem !!
I have a 1985 TPI 305 IROC, the thing is in slow city driving in the summer the temp stays 220-230 but when i get on the highway it gets up over 250, the fan is working fine and the coolant is at the right level any reason why it gets hotter in the highway???
Old Jul 15, 2003 | 11:43 AM
MechCD's Avatar
Car: '92 Camaro RS, '93 Ranger
Engine: LO3, Vulcan
Transmission: 700R4, M5OD
Axle/Gears: 2.73, 3.45
Is your air dam intact? A bent or missing one would increase your highway temperatures
Old Jul 16, 2003 | 11:01 AM
MdFormula350's Avatar
yeah i would check the air dam, its under car, under the radiator.
could also be the lower hose from the water pump to the radiator collapsing.
start off by checking those two items first.
Old Jul 18, 2003 | 02:31 AM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
Mine's doing the same thing. I have a new water pump, new hoses, new clamps, a new radiator, and no leaks. My air dam is intact but I'm wondering if it's developed flex and maybe doesn't hold it's ground at highway speeds. I was going to support it or maybe tilt it slightly up with some brackets or something.
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
chazman
Aug 22, 2015 02:01 PM
