Spal Fans
Old Jul 31, 2003 | 04:32 PM
355SS's Avatar
Car: 90 Camaro
Engine: 418 LS3 whipple charged
Transmission: Magnum T56 w/ Street Twin
Axle/Gears: 3.27 9 bolt
Spal Fans
I have been thinking about replacing my factory dual fans with the Spal dual 11" fans. I am seeing high head pressures with the stock fans and if I put a fan in front of the car it lowers the head pressure. I did a search and I am finding conflicting info if the dual spal's are really better than the stock ones? Anyone who has done this swap I would really like to get some first hand advice. If there is no difference in the fans then I guess I will have to get a crossflow condenser. I have no problems with the A/C when I am running 45 or faster and I have no cooling problems either. I am running a griffin radiator with dual 1.25" cores and I think this radiator is too much of a flow restriction. Any advice?
Old Aug 1, 2003 | 04:01 PM
355SS's Avatar
Car: 90 Camaro
Anyone?
Old Aug 2, 2003 | 10:11 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I have not done this swap but, I don't think the Griffin radiator is the problem. The more popular aftermarket fan swaps I've read about on this board is 2 independant 12" or a dual 12" with built in shroud like the flex a lite 200 series.
Below is very comprehensive list of aftermarket fans I found, that may help!
https://www.thirdgen.org/techbb2/sho...hreadid=193415
Old Aug 4, 2003 | 08:31 AM
355SS's Avatar
Car: 90 Camaro
Thanks for the link, I still would like to have some first hand experience if the aftermarket fans do work better than the stock dual fans.
Old Aug 4, 2003 | 10:26 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Can anybody supply the CFM rating on the OEM Factory dual Fans?
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
