AC question?
Old Aug 6, 2003 | 07:04 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
AC question?
I know this is probably the wrong forum, but I didn't know where to post this. I have an 85 IROC and I wanted to know what type of freon it originally used.
Thanks.
Old Aug 6, 2003 | 02:13 PM
larsulrik's Avatar
Car: 1992 RS
Transmission: A/T
R12.
Old Aug 6, 2003 | 06:35 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
i got mine charded today, using r34, i recomend u using r34 my uncle does repairs on a/cs, got mine working today, cost me under 20 bucks if everything is working properly, if urs isnt workin at the momemnt, check your clutch on your compresster, if it moves then ur compressor clutch is good which is often out on thirdgens, then take it from there, hope this helps
Old Aug 7, 2003 | 06:56 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
ya it works, just wasn't cold anymore. I don't think its ever been charged. Thanks guys.
Old Aug 9, 2003 | 12:57 AM
BoDeaN's Avatar
Car: '86 Transmaro
Yeah, switch your R-12 over to R-134 if you can. R-12 is sooooo damn expensive. Mine needs charging and it's still R-12, so eventually I'm just going to switch over. I hear it's not too hard of a process to do yourself.
Old Aug 9, 2003 | 01:05 AM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
R-12 is colder than R-134A I hear. But I hear 'ya. R-12 is getting expensive!
Old Aug 9, 2003 | 05:40 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
If you can get 12 and you system doesn't leak just top it off with 12. The cost of a proper conversion to 134 will be MORE than what 12 will cost, plus you'll still get snow from the ducts as opposed to 134 which takes longer to get cold even in a vehicle designed for it. If you are down a pound you may be only talking $60 bucks or so for a fill.
Old Aug 9, 2003 | 09:22 AM
Engine: 305 tpi
u all may say im stupid or something, but hell, u dont need the kit to swith over to r134, its just a waist of money to tell u the truth, my uncle is a mechanic and has worked on a/c's his whole life, and he says that u dont even need the kit, so he done mine, without the kit, and its colder than my moms brand new s10, so u all take it fromt here, if u dont believe me, then try for yourself, and if u think im wrong, prove me wrong, if u can,
Old Aug 9, 2003 | 04:45 PM
BoDeaN's Avatar
Car: '86 Transmaro
I really wouldn't want to prove you wrong if that's the case.
Old Aug 10, 2003 | 06:57 PM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I'm not worried about the cost of R12. Where I'm going, I don't have to pay for it. Its not what you know, its who you know.
Old Aug 10, 2003 | 07:37 PM
BoDeaN's Avatar
Car: '86 Transmaro
Well in that case, lemme tag along with you and get some of that free stuff.
Old Aug 11, 2003 | 08:10 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
As long as you don't mind the drive. I'm about 30 miles south of DC.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
