location of temperature sensor
Old Aug 9, 2003 | 11:40 AM
PeterW's Avatar
Hi everyone
Ok - this is probably the dumbest question, but I'm trying to locate the temperature sensor that activates the cooling fan on my 1989 Firebird 305 TBI. The car overheated today and the fan didn't come on at all so I guess the sensor is fried.
The Haynes manual says that V8 cars have the sensor located on the front of the left hand head, but the only sensor I can find is actually screwed in on the front right hand side, just off centre and in front of the throttle body.
Any help would be much appreciated
- by the way - the fan doesn't come on when I switch on the air con either - I noticed this mentioned in the FAQs - does this mean it's a relay rather than the sensor? If so, any ideas where the relay is located - the Haynes manual is no use at all
Old Aug 10, 2003 | 04:13 PM
Jaddo579's Avatar
Car: 89 Camaro RS
Engine: Soon to be 406
Transmission: unknown most likely TH350
Well first of all your going to have to follow the wires coming out of the fan to find anything. I installed a fan switch into my 89 305 TBI and my car ran hot because the stock fan switch wasnt even connected. It is going to be closer to the back by the starter. It is a real pain in the *** to get to so that you can put the switch in but it is well worth the money and the work my car doesnt go a bit over 180 on my gauges. That is of course with a 160* stat but to answer the question it is closer to the fire wall by the starter. Good luck and tell me how it goes?
Old Aug 10, 2003 | 11:14 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
it is going to not be the one thats screwed into the driver side head, usually the fan one is in the intake manifold or in the thermostat housing,
the one in the head is the temp sending unit for the guages, single dark green wire
good luck
Old Aug 11, 2003 | 06:00 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Re: location of temperature sensor
Originally posted by PeterW
Hi everyone
Probably NOT the sensor, suspect the fan relay(a big problem with these cars) or the fan motor or supply voltage to it.
Old Aug 14, 2003 | 01:07 PM
PeterW's Avatar
Thanks everyone
It was the fan relay.
Once I found it, I took the cover off it and cleaned the burnt out contacts on the relay. It now all works again. I've ordered a new relay but the old one works again for now
dbrochard
Oct 3, 2015 12:43 PM
64goatman
Sep 9, 2015 01:09 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
willyjoejr
Sep 3, 2015 09:26 AM
tonys91rs
Sep 2, 2015 07:07 PM
