Stat question
Old Aug 13, 2003 | 09:04 PM
IroczCamar0's Avatar
Car: 1989 Pontiac Trans AM GTA
Stat question
I just put a new water pump and i seem to be running 225-240 on summer days, i am almost positive that i have the stock 195 stat, how much would my temp drop if i were to put in a 170 or maybe 160 stat?
-1985 IROC Z 305 TPI
Old Aug 15, 2003 | 11:11 AM
breathment's Avatar
195-170=25 degrees lower...
However keep in mind that even though you install a lower temp thermostat, your fans are still going to kick on at the same temp. i don't recall that temp right now, i think its around 215*. So your only going to notice a difference at high speeds or unless you install a new fan switch to kick the fans on at an ealier temp. http://store.summitracing.com/section.asp?d=5&s=308
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
