Major Issue with my Cooling System
Old Aug 26, 2003 | 04:47 PM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
In the middle of summer, I started to notice that my car would run at about 105 C. Thats about 10 to 15 degrees higher than normal. I just figured it was because it was a really hot day. Then I started to notice that on the same day it would run at its normal temp of 90 to 95, I would shut it off and go in to a shop or something, and come back and it would be running at like 105 again. I figured I should start investigating more. I left for holidays, and came back just over a week ago, and the car was doing the same stuff, except the temp outside was a little cooler. Today however, my car was running at like 117 C, and it red lines at 135 c. So now I am really worried. Does anyone have any suggestions??
The radiator is about 1 year old. It looks in good condition. Im not leaking any fluid anywhere that I can see. My cars not puffing white smoke. So I am thinking that its the water pump?? How would I test that?? Could my thermostat be sticking?? WOuld blockages somewhere in the system cause these symptoms?? Any info would be greatful.
CHeers
AD
Old Aug 27, 2003 | 08:52 AM
Godti's Avatar
Car: Trans AM
Engine: 305 TBI
Transmission: 5spd
I talked to a parts guy, and he said that it could be my Heater core. Is this possible??
Old Aug 27, 2003 | 03:12 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Yes. Your radiator may need to be "rodded out" (thouroughly cleaned). I'd replace the stat as well.
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
NBrehm
Aug 25, 2015 11:49 PM
sreZ28
Aug 14, 2015 07:48 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
