how is fan controlled on various models?
Old Sep 1, 2003 | 08:29 PM
eddie jr's Avatar
ok, I am a little confused here. I thought the cooling fan was controlled by the computer. From reading some of the posts, some are controlled by a coolant switch. Did this vary throughout the generation (some controlled by the computer and some by a switch)??
Does anyone know what is was for 85??
Mine is an 85 2.8L.
thanks.
Old Sep 3, 2003 | 08:57 AM
eddie jr's Avatar
Can anyone help out with this??
Old Sep 4, 2003 | 10:07 AM
Zap Racing's Avatar
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
Read Willie's article above! Tell U everything U need to know!!!
Old Sep 4, 2003 | 06:05 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
my 86 single fan is controlled from the computer read of the speedometer.
Old Sep 11, 2003 | 01:19 PM
84L69TA's Avatar
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
What????? Its controlled by a coolant temperature sensor. I dont know about other years, but in my 84 the sensor for the fan in in the passenger side head between #6&8, and the temp sensor for the computer is in the thermostat housing.
Diggler86: So youre telling me that since your cars fan "works off the speedometer" , if your car is idling in park the fan wont come on?
Old Sep 11, 2003 | 01:54 PM
Diggler86's Avatar
Car: 86 TA
no, the fan is on when im in park idling. it turns on when i start the car.
on the upward slope, it turns off at about 50 mph (and anything greater its off)
on the downward slope, it turns on at about 30mph (and anything less its on)
between 30 and 50 depends on which speed you came from, increasing or decreasing.
trust me, i couldnt figure it out for the longest time since i thought it was controlled by the temp as well, but it never corresponded. i have an led that tells me when its on. the ecm definately reads the speedometer to tell the fan when to turn on and off.
if you think about it makes sense, when your driving at high speed, theoretically anyway there would be more airflow coming up from the airdamn so the fan would not be needed. then, at low speed, you need the fan on to bring air through the radiator.
maybe i have a freak car? but thats how it works, im sure of it.
64goatman
Sep 9, 2015 01:09 PM
Jlanz55
Sep 6, 2015 02:35 PM
85Special
Sep 3, 2015 04:21 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
