Buick Fan Switch?
Old Sep 1, 2003 | 09:50 PM
Trevor K's Avatar
Buick Fan Switch?
I've done the reading, and I want to purchase a new fan switch.
I have a 87 Z28 with the LG4, non-CC. So I don't need to worry about how low I go since my carb will squirt the same fuel regardless right?
With that in mind, what's the lowest fan switch I can get (And it's turn on/off temp's)? I don't want to spend $50-60 on an adjustable one, I'm hoping for a stock replacement.
Also - if you have the part numbers that would be helpful.
Old Sep 3, 2003 | 01:22 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Ive heard the GN switch will work and is lower BUT I could be wrong. Let someone verify that before you go buy one,.
Old Sep 3, 2003 | 01:59 PM
Trevor K's Avatar
Can anyone verify?????
Old Sep 6, 2003 | 09:56 AM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
the GN switch is lower, not much though, mine turns on at 220-225
here is an aftermarket one for $19 though
you only need the switch, not the harness(only vettes)
http://shop.store.yahoo.com/zipprodu...c5/pm-174.html
Old Sep 8, 2003 | 10:10 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
is there a factory type fan switch that turns on the secondary fan around 215*???
which one?
Old Sep 8, 2003 | 11:29 PM
Dave Y's Avatar
Engine: 4.3L V6
again, closest i've found was the GN switch, it may turn on slightly lower then i listed, but not much
FormulasOnly
Sep 10, 2015 09:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
