did search: v6 rad. ok for 350?
Old Sep 9, 2003 | 09:23 AM
vic_V8's Avatar
Car: RS
Transmission: 4L60
I'm sure the topic has come up before but the search won't allow v6 as a word,
I have a radiator and electric fan off of an 86 v6 SC, I'm hoping to us it on the 350 I'll be putting in the 84 TA, I'll end up putting a 160 stat in the car, the 350 will be pretty mild, about 9:1 compresson and putting out about 250 hp.
thanks for the help guys,
Vic
Old Sep 9, 2003 | 11:09 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
IIRC the upper radiator hose is on the wrong side for a V8; could be wrong though.
Old Sep 25, 2003 | 11:51 AM
kahamri's Avatar
Car: Camaro
Engine: More than one
Transmission: More than one
No your right..The 350..and v6 are diffrent...diffrent oem numbers and everything...
91 &92 350 has it's own radiator
82-89 2.8 has it's own also..
so you cant use those.
the rest should use oem number is 3056962..but i'm not 80% sure on that..
Old Sep 30, 2003 | 02:46 PM
shiner16's Avatar
Pretty sure the V6 unit won't handle it. My 355 makes around 300hp, and a brand new four-core V8 stock replacement rad. barely does the job when sitting in traffic or on hot days. I think I'm running a 180 tstat, I think.
Old Oct 4, 2003 | 08:25 PM
90firebird's Avatar
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i've heard the 90 and up 3.1 radiators are the same as those used on v8's.... but i'm not sure about older ones....
Old Oct 7, 2003 | 06:23 PM
breathment's Avatar
true. even though i don't think the part #'s are the same from GM. they ARE however the same radiators..
USA-1
May 23, 2002 10:20 AM
