No Heat
Old Sep 21, 2003 | 07:50 AM
montyx79's Avatar
Car: 1992 Camaro RS
Engine: 350 TBI
Transmission: a slipping one. lol
No Heat
Just finished my 350 swap got it all back together as the 305 came out, replaced radiator hoses, radiator, thermostat, checked all vac and hose lines, did full flush on system with correct mixture added. To no avail i have no heat, blower motor turns on but blows cold air only, is there any way to check the heater core? Any other suggestions would help, gettin chily in the morning here and cant drive it with the tops off Thanks for all ur help
Old Sep 21, 2003 | 08:06 AM
armac's Avatar
Car: 83 ta
check the hoses coming in and out of the heater core. the core could be stopped up. make sure your mixture falp is moving and if you have a air compressor you might blow some air through the heater core and see what comes out
Old Sep 21, 2003 | 11:14 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
The Heater Control Diverter Valve might be stuck in the closed position preventing coolant from flowing into the heater core. Just replace it with a new one.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
bryan623
Sep 19, 2015 10:13 AM
