Coolant Leak??
Old Sep 29, 2003 | 06:18 PM
Matt_Ky's Avatar
Car: 1998 Camaro Z28
Coolant Leak??
I went to Subway for lunch, got back out to my car and saw a coolant trail running down the parking lot. I went back to work ate lunch, let the car cool down and then checked the water in radiator and put in less than a 1 quart of water/coolant mix. Temp guage not over 180 degrees, however, I run a Derale temp controller.
Drove home after work shut it down same thing, leaking again. Let it cool down, put in some water.
Turned off Derale to run factory setup, let the car idle through three cycles of reaching temps of 220, watching for coolant leak, nothing. Shut it down and then it starts leaking.
It only leaks when I shut the engine off. It looks like its leaking from the lower radiator hose, however, seems like it would leak all the time if it were a hose. Any ideas? water pump or hose?
No noise from water pump.
Old Sep 29, 2003 | 07:43 PM
mikes92rs305's Avatar
waterpump
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
