Is this a problem.......????
Old Oct 9, 2003 | 12:17 AM
FLYNLOW92rs's Avatar
See where my gauge is? right below 160*
It has NEVER, I mean NEVER gone above that......even in the Florida Sun while i was sitting in traffic.........
Is that a problem? Or is my cooling system just that good??
Yes i know i'm almost out of gas and my oil pressure is broken......
Old Oct 9, 2003 | 09:28 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
That is not normal, I would change the "coolant temperature sensor" on the front of the intake manifold.
Old Oct 9, 2003 | 09:56 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I second the coolant temp sensor. You might also try tapping lightly on the gauge itself. Maybe the needle is sticking a little bit.
Old Oct 11, 2003 | 05:43 PM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Get a REAL temp guage (auto Meter, etc.)
Old Oct 11, 2003 | 09:47 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
Yeah, what he said...
Old Oct 16, 2003 | 12:23 AM
breathment's Avatar
changing the coolant temp sensor on the front of the block won't do anything at all for you. the sensor for the guage is on the drivers side head between 1&3 i believe and has a single wire running to it. what thermostat do you have in your car? and thats hight then 160* the guage is non linear
