intake manifold cooling idea
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
ok, so i just got a set of Vortec heads for my 350, and i got a performer rpm to with them. the vortec heads don't have an exhaust crossover, so edelbrock put one on their manifold so you can plumb it with exhaust or coolant to heat up the intake manifold. its externally plumbed (two 1/2 inch plugs, one on each side of the manifold).
i got to thinking at work today. what if i put an extra reservoir under the hood of my car, filled it with ice and water, and ran the ice cold water through the crossover under the plenum with an electric pump?
it seems to me that it would have the same general effect as icing down the intake. i would think that 40 degree water would be better for the intake charge than hot exhaust or antifreeze.
possibly a second pump piggybacked on the return side with a pickup tube so i could get the water out when i didn't want it to be there. straight water boiling under the plenum sounds like a bad idea.
any thoughts or opinions why this would/wouldnt work are greatly appreciated, as are ideas on how to set this up. (my strong suit is "african engineering", i suck at fabricating)
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
why go through the trouble of plumbing a icing system for your manifold when you can just put ice packs or something on it. just seems like a lot of work. i am pretty sure those exhaust crossovers are there for a reason as well.
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
wouldnt the difference in temperature pose a threat of cracking the manifold?
just like how people dont want to spray water on a hot engine because it could crack the block?
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
