fluid leak
Old Oct 20, 2003 | 08:25 PM
Firl's Avatar
fluid leak
When the engine is running somwhere in the back near where the tranny is connected the anti freeze is leaking in a steady stream out. Its not from any hoses on the engine nor the radiator. I am unable to go look and see where it is coming from, because I am 250 miles away from my car, just have my dad working on it. he makes it sound like its not coming from the heads, or anything on the top of the engine, is it possible its one of the freezer plugs cracked ? and is leeking from the back of the engine? if so are those easy to replace without pulling the engine?
Old Oct 21, 2003 | 11:02 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
It might be a bad rear intake gasket. Mine leaked down the back of the block to the transmission area. Pretty much just have to remove intake, distributor, and stuff and then slap new gaskets down and reinstall everything and run a timing light and you should be good to go again. If it's the intake leaking.
Old Oct 21, 2003 | 02:10 PM
Firl's Avatar
that would be amazing, heh wouldn't need to do too much work, just new sealant goop. I could probabbly get it all done in under 1-2 hours.
FormulasOnly
Jul 23, 2018 08:47 AM
Mark_ZZ3
May 24, 2018 01:02 PM
jrdturbo
Mar 31, 2016 02:58 PM
HikoriYami
Sep 21, 2015 07:11 PM
Stryker412
Sep 20, 2015 06:59 PM
