Deionized or distilled?
Old Oct 24, 2003 | 10:25 PM
25THRSS's Avatar
Which is better for my cooling system and why?
Old Oct 25, 2003 | 02:06 AM
rezinn's Avatar
Realistically they would both probably be about the same. Deionization removes polar ions (calcium and such), which could reduce any buildup in your cooling system, but distillation is made to remove solid material or liquid of differing volatility, which will also remove many of these ions. Distilled, then deionized water would be the best, but that is something used in a laboratory, not in engines. Also, the quality of either depends on the equipment used to make it, so one may be better than the other based on that. The difference between the two would be minimal. Any water you put in your engine will lead to some kind of corrosion. Deionized or distilled, probably doesn't matter as long as you don't use tap water.
Old Oct 26, 2003 | 12:09 AM
25THRSS's Avatar
anyone else?
Old Oct 27, 2003 | 02:16 AM
bigals87z28's Avatar
Car: Check The Sig
Well, if your that **** about it(hehehe) id go with distilled. Id say its cleaner then deionized water just because of the proccese of distilation.
Old Oct 27, 2003 | 05:29 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Texaco who invented Dexcool for GM states and I quote"good quality tap water" when they give filling instructions. In the scheme of things it really makes no difference unless you have water that a spoon will stand up in. Certain areas of Europe have water like that and I know that Honda for thier liquid cooled cycles warns owners not to use tap water in products marketed there. I don't worry about it one way or another, if the cooling system is in good shape and properly maintained you should be fine with what you put in your belly.
Old Oct 29, 2003 | 07:19 AM
kevinc's Avatar
Car: 1982 Z28
I use Shell pre-mixed coolant, two things on the label that I like:
1.) low-silicate formula
2.) diluted with deionized water
-Kevin
Old Oct 29, 2003 | 07:23 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i just use tap water since the water here doesnt have any heavy deposits.
besides, i reverse flush and fill my car more often then once a year..
when you work on the car(heads, intake, anything that opens the cooling system) you end up replacing it anyway....
Old Oct 29, 2003 | 09:02 PM
25THRSS's Avatar
The next question would be where can you get deionized water?
Old Oct 29, 2003 | 09:04 PM
Car: Check The Sig
anywhere. I just drank a gallon of it yesterday and i got it from Target. 79 cents and I was set.
Old Oct 29, 2003 | 09:10 PM
25THRSS's Avatar
damn, all the grocery stores around here only carry distilled. Sometimes I really dont like virginia.
Old Oct 29, 2003 | 10:39 PM
Car: Check The Sig
Try an autoparts store.
Old Oct 31, 2003 | 08:54 PM
kevinc's Avatar
Car: 1982 Z28
Check the baby section of the grocery or drug store. Super-pure water tends to be there, paranoid new moms just can't get clean enough water for mixing powdered formula.
Old Nov 9, 2003 | 05:35 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
i remember someone peeing in his rad on the side of the highway one day, i guess he had no water
Old Nov 9, 2003 | 08:32 PM
onebinky's Avatar
I bet the steam from that smelled good
Yeah, if the grocery stores by you don't have it try the autoparts store. The ones by us keep it by the batteries, I guess for if by some chance you have one of the old non-maintnence free batteries.
Old Nov 12, 2003 | 04:42 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
I use good old Chicago water!! The best TAP water in the country!!
Kevin
abray1
Apr 12, 2013 06:55 AM
purg3d
Mar 26, 2006 04:21 PM
safemode
Nov 14, 2005 08:39 AM
azvolfan
Oct 25, 2005 10:46 PM
Dante93GTZ
Feb 22, 2004 12:55 AM
