get's hot and won't start
Old Oct 29, 2003 | 11:24 AM
coonican's Avatar
Car: 85 Z28
Hello all, this is my first post cause this the first time i have had a problem with my car, it's a 85 Z28, 350tpi, the problem is today as i drove up to the trusty Food Lion, shut down my car, went shopping, arrived back at my car to find out it would not start, after sitting there for 20 or so minutes it finally started, if anyone has had this happen to them before and fixed it or know what the problem is pleas email me
thank you
Old Oct 29, 2003 | 03:34 PM
coonican's Avatar
Car: 85 Z28
nervermind
well hell, guess the situation just got worse, stared once and now nothing, as before, time to look underneath
Old Oct 29, 2003 | 09:21 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Do a search. I believe this can occur from heat soak on the starter. My guess is the starter is starting to go bad. That's what mine did acouple times before it died.
Old Oct 29, 2003 | 09:30 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
its is either starting to go bad or it is getting hot and just not working. i had an old f150 that did that. not to cool on 20* - weather conditions waiting to leave the gas station.
Old Oct 30, 2003 | 03:25 PM
Abird4u2nv1's Avatar
Car: 89 Firebird Formula(Totalled), 91 C
Engine: Mild 350
Axle/Gears: 2.73 :-(
Sounds like the infamous heat soaked starter, check the tech articles, really nice one about how to cure that.
Old Oct 31, 2003 | 06:47 AM
coonican's Avatar
Car: 85 Z28
thanks guys, had to put a new starter in last night, not to bad of a job, thanks for the replies
Old Oct 31, 2003 | 11:14 AM
Engine: Mild 350
I would look into the remote solenoid article still, otherwise you'll probably have the problem again.
Old Oct 31, 2003 | 01:31 PM
coonican's Avatar
Car: 85 Z28
thanks
Old Nov 3, 2003 | 12:16 AM
sllt1776's Avatar
Car: 89 Iroc-Z
yea i was having the same problem. sometimes it would take an hour to cool enough. i bought the remote solenoid and it fixed the problem. hasn't happened since. you probably could have just gotten away with that. 30 bucks and about 1 hours to install taking my time.
Old Nov 3, 2003 | 02:07 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
If you have heat soak like everyone says, simply replacing the starter is not the solution, but a temperary fix.
I had this exact problem and it was caused form heat soak. A new starter will work for a while but will still suffer the same death as the first(if its heat soak). The problem is easily fixed with a $25 starter shield that block some of the heat from soaking into your new starter. Here is what saved my starter from heat soak
Old Nov 3, 2003 | 07:17 PM
sllt1776's Avatar
Car: 89 Iroc-Z
sweets10v8 is right about your starter dying the same way but i think a remote solenoid is a better route over the heat shield. it is about the same cost and you wont have a part that will trap moisture and dirt and also be a potential fire hazard. just my 2 cents.
Old Nov 4, 2003 | 11:12 AM
Engine: 383 SBC
I never experienced heat soak with my OEM starter (no clue how I avoided it) since I was always running hot and my Y pipe and TES headers come pretty close to the starter... One day my starter act'd up then died a day later... mine was just a faultly starter... I went to a mini starter and I got even more clearance.
Would a mini starter help out any since it would provide more air space between the motor and the exhaust?
Old Nov 4, 2003 | 04:01 PM
coonican's Avatar
Car: 85 Z28
thanks for all of your replies again, think i might go to the remote solenoid, just to save a few bucks.. now that i have it running and the tbird for a spare, time to get some more hp out of it.. thanks again
coonican
theshackle
Mar 5, 2017 06:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
86Base
Aug 8, 2015 01:34 PM
