Be Cool Radiator Module
Old Nov 10, 2003 | 11:23 PM
87-5.7iroc-z's Avatar
Car: '87 IROC-Z
Engine: L98 TPI/Possible LS1 swap
Is any one running the module? The radiator with the fans and the fan controllers. How do you like it and how was the fit?
Old Dec 28, 2003 | 01:40 PM
Car: '87 IROC-Z
Nobody
Nobody has one of these?
Old Dec 28, 2003 | 04:47 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I'm running the radiator and it helped with teh cooling but wasn't the entire answer. I am running my own cooling fan setup.
It bolted right in but the lower radiator hose is better being slipped on before you lower the radiator all the way down. You also need a fitting for the heater hose and fittings for the transmission cooling lines. I found them at a local "Mom & Pop)parts store (Not a Kragen or Autozone type store)...
Old Dec 29, 2003 | 02:52 PM
86bird's Avatar
Becool
I have the Radiator and dual Spal fan set-up, but not the fan control. The Rad fit very well, just follow the instructions. Mounting the fans involved cutting the stock shroud and fabricating new mounts. Becool supplys some mounting hardware at extra cost, but minor fabrication is still needed. I am running a Stewart stage 1 pump and drilled 180 degree thermostat in an 86 T/A with a mild 406. The temp is controlled nicely.
Bubbajones_ya
Jul 6, 2024 08:32 PM
steimel94
Sep 23, 2015 12:48 AM
wisemanz28
Sep 20, 2015 01:26 PM
84redta
Sep 19, 2015 09:58 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
