Stock radiator material?
Old Nov 26, 2003 | 12:21 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hi my radiator from my 82 S/E seems to be broken
on the right tank.it leaks lots of water and
i wanna fix it. but i don't know if the stock radiator
is metallic or plastic.
maybe i can't fix it.maybe yes
please help
Old Nov 27, 2003 | 06:40 AM
Calderone's Avatar
Car: 87 Vette
No info ?
any info ?
Old Nov 27, 2003 | 10:48 AM
Thirtybird's Avatar
Car: 91 Z28/99 WS6/02 WS6
Engine: All 350's :)
Transmission: 700R4 & 2 Tremec T56's
this may not help - you'll have to check your radiator yourself. My 87 was a metal core with plastic tanks on each end. I got a small hole in one of the tanks and used plastic epoxy to fix it. That worked for a while until a larger hole formed. That being said, something has caused your tank to split (too much pressure) - if you fix it yourself (which is possible) replace the radiator cap as a precaution.
Old Nov 27, 2003 | 10:57 AM
Calderone's Avatar
Car: 87 Vette
the broken part is too large
Too large is the broken part and
the tanks are plastic.
I will replace the tank with a copper one
Old Nov 27, 2003 | 10:25 PM
breathment's Avatar
both have their advantages. aluminum is alot stronger but yes the side tanks are sometimes weak. but at least it wont corrode through and explode. (by explode i mean leak... )
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Bstrang6
Aug 26, 2015 11:39 AM
Golfvette
Aug 24, 2015 06:35 PM
