Single core radiator ?
Old Jan 16, 2004 | 09:17 AM
my3rdgen's Avatar
Car: 2013 Challenger RT
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
My 87 T/A has a single core radiator with the wide (an inch or so) core that is about as wide as an older 2 core. It was new when I got the car and I have only put 500 or so miles on the car since. I'd rather not replace it, but I am wondering if this is a suitable radiator for use with a performance engine(300 net HP). I haven't had the car out in the summer yet, so I do not know how it will react in the hot weather. It is just a weekend cruiser (once or twice to the track per year).
Any suggestions?
Old Jan 16, 2004 | 12:28 PM
MdFormula350's Avatar
i would think you will be fine, a 180 or 170 stat with a good eletric fan should keep you plenty cool.
Old Jan 16, 2004 | 09:59 PM
my3rdgen's Avatar
Engine: 5.7
Transmission: 6 spd
Axle/Gears: 3:92
I forgot to mention that I modified the intake to a 4 point cooling system too, and bought the addapter to samich between the stat and intake. (routes coolant from back of heads to front of engine under the stat)
Old Jan 17, 2004 | 05:00 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: Single core radiator ?
The stock one row alum. radiator in the 85(?) - 92 third gens works great. 300hp = no problem. Just gotta make sure fans & rest of cooling system are up to par.
sheachopper
Jul 31, 2019 11:27 AM
LT1Formula
Oct 8, 2015 08:34 PM
