How to hook up my heater core.
Old Jan 22, 2004 | 09:09 PM
mist1006's Avatar
Car: 86 Camaro Z28
Engine: 350 built
I went from a 86 TPI 305 to a 74 block 350 carbed and i wanna hook my heater core back up.
not sure how to do it since the old heater core was hooked up through the throttle body.
any thoughts?
if pics are needed i can get them.
Old Jan 23, 2004 | 12:02 AM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Where on the engine are the fittings for the hoses? If there is one on top of the manifold beside the thermostat housing, and one on the water pump you can use those.
Old Jan 23, 2004 | 07:05 AM
mist1006's Avatar
Car: 86 Camaro Z28
Engine: 350 built
awesome thanks we have both
which way should we hook it up... does it matter?
Old Jan 23, 2004 | 04:46 PM
The heater core itself won't care which way the coolant flows through it, but the fittings on it are two different sizes - 5/8" and 3/4". Generally, the 3/4" is the inlet coming from the fitting on the intake manifold. Here's how I have them routed on my Formula
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
