Cooling Fan Problem
Old Feb 11, 2004 | 02:54 PM
simifast's Avatar
Car: 1991 Z-28 Convertible
Cooling Fan Problem
Fellas:
I have a 1991 Z-28 dual fan cooling system. One fan kicks on when the A/C is turned on but that's it. Isn't there a sensor for that fan when the temp reaches a certain point? I know both fans themselves work because one kicks on with the A/C and I swapped wiring and the other fan came on with the A/C. I checked the relays on front driver side and they SEEM fine. Temp gauge works ok. Could both sensors be bad for both fans? What is left to check?
Old Feb 12, 2004 | 12:14 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Theres a temp switch on passenger side head.
Old Feb 12, 2004 | 02:49 PM
simifast's Avatar
Does this control both fans? Do you know where it is on the pass side head? Is it easy to replace? Thanks
Old Feb 13, 2004 | 10:17 PM
MdFormula350's Avatar
the drivers side fan works off the coolant temp sensor in front of the engine. and basically it should come on around 228
the passengers side fan works off the a/c pressure switch, fan switch in the passengers side head (between 6 & 8)
Old Feb 16, 2004 | 11:07 PM
simifast's Avatar
Does anyone have a picture of where the pass side temp switch ois? I think I found the drivers side. When the A/C is turned on the fan should kick in but it also should kick on when the temp goes up, correct?
Old Feb 29, 2004 | 11:46 PM
BottlesR4Babies's Avatar
Car: 91 Z28
Engine: 350 TPI H.O.
did u get that fixed yet? cause i have the same exact problem with my 91 z28
Old Mar 1, 2004 | 01:53 PM
simifast's Avatar
No I have not fixed it yet. I ordered the front sensor from Pep Boys, waited a week, called them and they said the part never was ordered and now the factory is out of stock. Morons. I may look around and see who has the part in stock. I have checked I believe everything else and I'm left to this. I will let you know soon. Keep in touch
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
JHX
Aug 29, 2015 02:30 PM
Leggman1
Aug 6, 2015 04:15 AM
