Wheres the thermostat located?
Old Feb 22, 2004 | 07:10 PM
mota420's Avatar
Where the thermostat located and which one is the best choice... 160 or 180 degrees?
Old Feb 22, 2004 | 09:33 PM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
Ummmm, which engine do you have?
But the easiest answer at this point is follow the upper radiator hose to where it enters the engine. The hose will attach to a metal neck which then attaches to the engine. Under this neck is where the t-stat is.
As for what temp... that is up to debate. I personally use a 180*. I wouldnt use a 160* or 170* in a computer controlled car unless you get the computer reprogrammed for it. Even with the 180* I am looking at having to get it reprogrammed. (for other reasons as well, but this is a major one).
As always, YMMV
james
Old Feb 23, 2004 | 10:48 AM
MdFormula350's Avatar
follow the main radiator hose thats on top of the radiator.
180 is what i use way better than the stock 195.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
