strange overheating problem.
Old Mar 1, 2004 | 07:12 PM
sleeperZ28's Avatar
Car: 86 z28
Transmission: built 700R4
my 86 z28 does this strange temp flucuation while driving down the road. at random while driving temp gauge goes from normal of 160ish then comes up to over 260 stays there for about 40-50 seconds then goes all the way back down to 160. doesnt happen all the time and after it happens once it could be 20 min or so before it happens again.
cooling system specs. 3" griffen rad, weiand hi-flow aluminum water pump, milodon hi-flow 160 tstat,stock electric fan.coolant sensor in drivers cylinder head
Old Mar 1, 2004 | 07:22 PM
cgb's Avatar
cgb
BEFORE you do ANYTHING ELSE...
Install a mechanical or electric ( I like mechanical ) AFTERMARKET temp gauge, even temporarily to see if the gauge is just acting foolish as MOST GM gauges from the 80's do.
Old Mar 1, 2004 | 09:25 PM
acescarrsRS's Avatar
Car: 89 RS
Engine: 383 in building process
Just food for thought, but it is possible to have a faulty thermostat also, even if it is new!!! Happened to me. Also I second that thought of hooking up another gauge just to see.
Old Mar 2, 2004 | 05:52 PM
sleeperZ28's Avatar
Car: 86 z28
the thermostat i took out looks to be the exact same as what i put back in. it has the same numbers stamped on it. engine did the same thing with the old one.
all of the parts listed were replaced mostly one at a time as they needed replacement, not to try and fix this problem.
thanks for the pointers i'll try a different gauge once i put my car back togather(currently tore down to get full paint job).
Fanatic1074
Oct 3, 2022 05:57 AM
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
HoosierinWA
Oct 7, 2015 10:15 AM
