electric fan Q
Old Mar 7, 2004 | 07:17 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
electric fan Q
Right now i have a good 'ol 6 blade flex fan on my 355 and it seems to put some drag on the engine. I can get an electric fan setup out of a 90 firebird for really cheep. do you guys think that i would actually notice a difference, or would the extra drag on my alternator offset the whole idea?
Thanks,
Dave
Old Mar 7, 2004 | 08:04 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It's a toss up. Electric fans will move more air when needed as opposed to a belt driven unit. Belt driven fans seem to keep the engine temp more stable. You can control fan turn on by using aftermarket fan control switches. As far as HP, 1 horsepower is equal to 746 watts. Dual fans when turned on will draw a peak current of about 20 amps or so then settle down to about 6-8 amps each. At 12 volts you would be looking at around 96 watts for each fan(P= ExI) where power is in watts I=current in amps and E is equal to voltage. Not really significant in the scheme of things. If you run them continuosly they will shorten the generators life somewhat. Hope this helps.
sheachopper
Jul 31, 2019 11:27 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Fanatic1074
Oct 2, 2015 03:47 PM
lanceflame44
Sep 25, 2015 12:28 PM
