cooling problem
Old Mar 11, 2004 | 06:19 PM
bad@ss89camaro's Avatar
Car: 91 Z/28 convertible
cooling problem
i have a 91 z28 convertible 305 tpi and i need some radiater help my top radiator hose keeps colapsing and the radiator builds up lots of sucktion where its hard to take the cap off and it pushis all the water back out the resivoir and still keeps a suction on the radiator and hose any ideas?
Old Mar 12, 2004 | 09:26 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Almost sounds like your water pump is either the wrong part or is spinning backwards. The upper hose is the pressure hose. The lower is the suction. Somethings got your system going backwards.
Old Mar 13, 2004 | 09:58 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Have you replaced your water pump lately? Some of them run the opposite direction.
Old Mar 15, 2004 | 01:46 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Huh?
as usual, these guys are right on the ball. A water pump for a serpentine system runs reverse of a non-serpentine small block.
Also, check and make sure your belt routing is right.
Honestly, this all sounds pretty weird. Your radiator might be plugged. Clamp your top hose, disconnect the bottom hose, and see if you get good flow out the bottom.
Sucking shut the top hose, but pushing coolant into the reservior sounds like the two halves of the radiator are not connected, and both those hook into the top of the radiator.
I have unplugged radiators by taking them out and lying them flat on the ground, and filling them with lime-away (pure stuff, not with the cleanser in it) and topping off with water. Let it sit for a few days, then rinse liberally. They usually come out shiny inside and flow like crazy
Good Luck
Troy
So Cal
chazman
Aug 28, 2018 03:25 PM
greenyone
Sep 2, 2015 03:39 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
chazman
Aug 22, 2015 02:01 PM
