help with cooling fan
Old Mar 21, 2004 | 10:12 AM
1991bluebird's Avatar
Car: 1991 firebird
i have a 1991 firebird with the 305 engine. it has one single fan. i cant get the fan to come on with the a/c off. i have changed everything but the computer......i need some help here....is there something i am missing?
thanks,
jeff
Old Mar 21, 2004 | 02:41 PM
MdFormula350's Avatar
did u check the fan switch or coolant temp sensor?
Old Mar 21, 2004 | 03:29 PM
Car: 1991 firebird
i have replace the coolant temp sensor. where is the fan switch located?
jeff
Old Mar 21, 2004 | 03:49 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
The fan switch is located on the passenger side cylinder head between cylinders 6 and 8. It looks kind of similar to the coolant temperature sensor.
Old Mar 21, 2004 | 03:51 PM
Benm109's Avatar
Engine: 305 TBI
I also have almost the exact same problem that you do. One thing that I am going to try is taking of the fan and then hotwiring it to see if it comes on with just battery voltage applied to it. Have you also checked the fan relay?
Old Mar 21, 2004 | 06:55 PM
Car: 1991 firebird
i have switched the relays around and i have applied 12 volts to the fan. the fan is goood just wont work without the a/c on.....anyone know what else i can do to fix this?
jeff
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
