What is correct oper. temp for LO3?
Old Apr 9, 2004 | 01:54 PM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
My car runs consistently around 140-150, maybe 200 stuck in traffic for a while. I do have mostly water in my system currently. Is this the cause?
(The engine is back to all stock parts.)
At what exact temp does the O2 sensor come into play?
What is the ideal temp for a stock LO3's ECM? Power/Economy
Old Apr 9, 2004 | 06:23 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The ideal operating temp for the L03 is 195-220. The car should enter closed loop(uses O2 senser input) around 160 but other factors can change that temp.
Running just water shouldnt make your engine run that cold. Usually when an engine wont warm up its due to a thermostat that is stuck open.
Old Apr 9, 2004 | 11:34 PM
25THRSS's Avatar
Mine will run an average of about 160 degrees with a new stock 195 stat. If I get stuck in traffic long enough it can reach as high as 220 where the fans kick in and cool it back down. 160 is fine and closed loop will be reached long before that.
Bubbajones_ya
Jul 6, 2024 08:32 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
64Chief
Sep 12, 2015 08:05 AM
86IROC112
Sep 11, 2015 04:04 PM
