new radiator install question
Car: 90 RS
Engine: 305 TBI - LT1 Cam
Axle/Gears: Stock Crap
my old radiator cracked on the side, so I had to run out and get a new one. my question is if I could run the engine with out hooking up the radiator to get all the old coolant out of the engine. would this work?
also, my air conditioning hasn't worked for a couple of years, so I just want to remove all the componets, does anybody have any pointers on doing this??
thanks
thanks
Car: 90 RS
anybody?
the reason i want to get the old coolant out of the engine is that what came out of the old radiator wasn't exactly green. it was more brownish green. I tried the drain plugs on the engine block, but they are pretty solid and i would rather not break one of those off and have to pull the engine to fix that. so i figured, run the engine till no more coolant comes out and that should be good.
feel free to tell me otherwise or suggest a better alternative.
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if you are super worried about that collant , hook up the radiator and run the engine with the radiator full of water. then after a few minutes drain and then refill with water or antifreeze. DO NOT run the engine without the radiator. why run the risk of wrecking something?
Car: 90 RS
yeah, i wasn't that worried, after three hours of driving around to get the right radiator, i decided to just hook it back up and add new coolant. when i get a chance, i'm gonna flush the whole system out.
Car: 1990 Firebird
Engine: LS3
i agree
I would definately agree, do not run w/o a radiator. as far as the AC system goes make sure all the refregerant is out (or reasonably close to) I haven't done this (I like my a/c) but if I was going to I wouldn't be going at it with a crow bar or somthng, just take your time on it. (I learned this stuff in the tech school I'm going to, which is for diesel btw) just my opinion
84z96L31vortec
Aug 20, 2017 12:16 AM
