question about water pump
Old Apr 20, 2004 | 01:27 AM
vampiroc's Avatar
Car: Z28
What does that little plug on top of the water pump "plug up"? is there any function for hooking it up?
Old Apr 20, 2004 | 02:24 PM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Transmission: Various
Axle/Gears: Various
It's for older heater core setups; it's a pressure line out I think but am not so sure now. I've had to route a temperature gauge there before; gives a cooler reading though.
Old Apr 21, 2004 | 05:52 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
nope, line in
line out is the intake, before T-stat
Old Apr 22, 2004 | 08:36 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I've often wondered about this (the direction of flow).
When you say "line out is the intake, before T-stat", do you mean the line out of the motor, or the line out of the radiator? In other words, please bear with this dumb old phart, does the water flow from the radiator through the top hose to the thermostat and then on into the engine, or the other way around?
Just curious...
Have a Great Day!
- Vern
Old Apr 22, 2004 | 11:54 AM
tpiroc's Avatar
Car: GM & Jaguar
Engine: Various
Axle/Gears: Various
The water pump is pulling coolant from the lower radiator hose then circulates through the block, and up to the coolant passage on the manifold to return coolant to the radiatior via top hose when then thermostat is open. Therefore the outlets/fittings on the manifold always releases coolant to the heater core. Is that right Dave?
Old Apr 22, 2004 | 07:45 PM
Dave Y's Avatar
Engine: 4.3L V6
yes
think of this, the t-stat is the only real restriction in the system, so the coolant is at the highest pressure before it, and lowest right before the w/p(tecnically right after the t-stat, but that is not doable on the gen 1 sbc...LT1's have it done that way)
Old Apr 23, 2004 | 09:08 AM
vernw's Avatar
Thanks for clearing that up for me folks. I appreciate it, learn something new every day!
- Vern
eightsixseven
Dec 16, 2024 01:50 PM
evilstuie
Jan 9, 2020 08:29 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
Street Lethal
Aug 12, 2015 11:33 AM
