Those of you who deleted your heater valve...
Old May 28, 2004 | 01:21 PM
25THRSS's Avatar
Did you notice any extra heat in the car at all? How well does your ac function compared to before?
Old May 28, 2004 | 02:35 PM
Virtualdemo's Avatar
Car: 1986 IROC Z28
Engine: 400 SBC
Axle/Gears: 3.42 Limited Slip
I have no difference at all. I live out in the desert and still havent noticed a difference. But I did notice a wee lil tiny difference in the AC operation. I am really picky on my cars so I notice the lil things but Deleting the valve was a good thing in my opinion.
Lates,
Demo
Old May 30, 2004 | 03:31 PM
92TRANSAMWS6's Avatar
Mine is gone along with the rest of the AC setup. People told me I'll regret removing the heater valve. Well I haven't had any complaints yet. My car still blows cool air on the vent setting as well.
Old May 30, 2004 | 06:54 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
where is the heater valve located?
Old Jun 1, 2004 | 01:29 PM
Car: 1986 IROC Z28
Engine: 400 SBC
It should be on the passenger side. If it actually has one it will have a vacuum line going to it and also three heater hoses connected to it. Both of mine were located just above the head close to the front of the engine. On the TPI one hose actually goes into the Throttle body and if you follow that one hose it takes ya directly to the valve. I wish I knew how to post a pic in here and show ya one....
Lates,
Demo:hail:
Old Jun 1, 2004 | 02:58 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
If you remove the heater valve that will allow hot coolent from the intake manifold derectly back into the water pump and into the engine bypassing the rad. In the summer this could raise coolent temps. I added a heater valve!!
Auggie
Old Jun 1, 2004 | 06:27 PM
Car: 1986 IROC Z28
Engine: 400 SBC
How can it possibly go direct? The valve redirects the water back thru the block rather than have it go thru the heater core. When you delete the valve the water flows thru both depending on how you do it.
The whole purpose of the diverter valve is to keep hot water from entering your heater core when you have your temp inside set to cold (flap closed to the heater core/ open to A/C and vent). ?????
Lates,
Demo:hail:
Old Jun 1, 2004 | 07:36 PM
Auggie's Avatar
On my 84 Camaro the inlet coolent that feeds the heater core comes from the eng. hot water return just before the stat on the int. manifold and has no heater control valve. The return water from the heater core returns to the top of the water pump bypassing the rad. All this hot water (you don't use your heater in the summer) goes from the water pump back into the eng. So, I installed a Monte Carlo heater control valve to stop the hot water from returning to the eng.
Auggie
Old Jul 16, 2014 | 11:50 PM
ShawnRS92's Avatar
Car: 92 camero rs 25th anniversary
Engine: V6 3.0
Transmission: Automatic
Re: Those of you who deleted your heater valve...
I want to remove my hoses that run to my heater coil I need help with what I need to do with the hose that comes off the water pump and the lil hose that goes to top of motor?
Old Jul 17, 2014 | 11:22 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
on my TPI car I have a heater hose going from the throttle body to the core.then from the core to a fitting on my stock rad just below the cap. with this set up obviously there is coolant passing thru the core all the time
Old Jul 17, 2014 | 10:28 PM
ShawnRS92's Avatar
Engine: V6 3.0
I took mine out today and I don't have AC either the temp went to 260 not all the up but it did get in the red a lil but it went down and stayed down wouldn't even get to 220
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
