finally fixed my overheating problem!
Old Jun 24, 2004 | 05:03 PM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i wasnt having an overheating problem during the winter, but once it got warm out, and i tried driving on the highway, i noticed a considerably higher temperature reading on my gauge.. lol i finally fixed the whole front air dam on my 89' formula firebird. when i bought the car, it had absolutely nothing on... i dont know how it wasnt overheating. anyway, i went to a junkyard, got the 2 side pieces that go in front of the wheel wells, and the center piece in the front and put it all together... problem solved. the car has never run cooler on the highway! i was very lucky i found the entire thing in one piece at a near by junkyard... seeing the last time i went they had no firebirds. this time they had a 1990 formula 305 there with the whole front intact. so i stripped it all off... i might take some more stuff tomorrow hehe just thought i'd share that with everyone! NOW MY TEMP NEVER GOES PAST 220!!! WEEEE
Old Jun 26, 2004 | 03:39 AM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Congrats... At least you didnt replace your entire cooling system to find out it was those missing parts that made the difference. Most people dont understand that cars are put together and made to work a certain way. Once you change something, theres a good chance it affects the car in a negative way. In your case, the car was running hot. Some people would have changed out the water pump, radiator, thermostat etc etc.. Good job!!!
Old Jun 27, 2004 | 02:37 PM
bigchief's Avatar
well i mainly didnt do any of that stuff b/c the problem wasnt really on idle... it was only on the highway, or when i was driving at a constant speed for a while. so i knew it was probably an airflow problem. i'm just glad its fixed... lol i might need a new radiator soon though, mines cracking a little bit b/c the people that owned it before me probably overtightened the clamps... damn plastic rads.... bla. anyway thanks
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
86IROC112
Apr 9, 2016 10:20 PM
Polo Z03
Sep 10, 2015 06:43 PM
dyeager535
Aug 28, 2015 08:10 AM
