Bigger Radiator with a Procharger????
Old Jul 7, 2004 | 11:23 AM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
I'm currently running a 388 with my D1-SC procharger. I feel the stock radiator is inadequate for my application even though it hasn't overheated yet. I have a 180* stat, stewart stage 2 pump, and a new stock size radiator. Is there anything i could put in place of it.
Old Jul 18, 2004 | 08:22 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: Bigger Radiator with a Procharger????
A Griffin...
Old Jul 19, 2004 | 12:29 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
You might try looking at the 180 buck griffins. Only main difference between them and the 400+ or 500+ buck models is theres no return line from the heater core and there isn't a built in trans cooler. Your stage 2 stewart should have a spot on it to plumb a return line to it directly. You could even try searching the net for them... Summit and Jegs should both price match. I eventually found a 31x19 for 160 bucks or so before shipping once.
Old Jul 20, 2004 | 06:01 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
If i'm not mistaken, the griffin's are a little thicker than stock. I have no room for a thicker unit. The only way i can stick a thicker unit is if the actual radiator were shorter and then i could stuff it under the radiator support where teh AC condenser was.
sheachopper
Jul 31, 2019 11:27 AM
sjorgens
Oct 1, 2015 07:54 PM
