bubbling sound why?
Old Jul 22, 2004 | 11:10 PM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
bubbling sound why?
Why is my car making a bubbling sound from
the rad when I turn it off?It also runs warm.
it seems to happen when i run it hard sometimes.
:rockon:
Old Jul 22, 2004 | 11:17 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
How old is the cap? It may need replaced.
Old Jul 22, 2004 | 11:42 PM
CaptPicardsZ28's Avatar
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Re: bubbling sound why?
:rockon:
Its either cuz you are running hotter than your gauge reads and the coolant is boiling or your rad is clogged. If you have any coolant leaks anywhere, air could be getting in the motor and would cause it to bubble. Do you have pressure in the hoses when the car is warmed up. No pressure means bad cap or air in system.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
